Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: sum(set[])
Given an arbitrary number of series, returns a single series where each value is the sum of the values at that point in time in all of the input series.
sum([
      sum(s("foo",{"@host": "prod.web*"})),
      sum(s("bar",{"@host": "prod.web*"}))
To sum over time use the integrate(set[]) function.
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
