Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: abs(set[])
Given an arbitrary number of series, returns the absolute value of the set by removing any present negative symbol.
abs([
   sum(s("foo.total", {"@host": "prod.web*"}))
Example:
The example below illustrates how abs() works. The chart on the left shows the raw metric with both positive and negative values. The chart on the right uses a composite with the abs() function.
composite_abs
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
