Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: filter(set[], options)
Given an arbitrary number of series, allows you to limit or exclude metric streams based on the values the streams contain. The filter function takes a series, a set of bounds, and an aggregate function. It applies the function to each stream and only returns streams whose result falls within the bounds provided.
  • gt - Greater than
  • lt - Less than
  • gte - Greater than or equals
  • lte - Less than or equals
  • function - Aggregate function applied to each metric stream. Must be one of
  • min, max, sum, or mean. Defaults to mean.
Example:
The following expression will return all streams for ELB instances whose average latency peaked above 0.025 seconds within the last hour (or whatever duration is selected):
filter(
  s("AWS.ApplicationELB.TargetResponseTime",
    {"name": "*"},
    {period: "60"}),
    {gt:"0.025",function:"max"}
The ELB instances whose average latency never went above 0.025 seconds are not rendered on the chart:
composite-filter-max
To only show ELB instances where the mean latency never dropped below 0.025 seconds during the last hour use function:"min":
filter(
    {"name": "*"},
    {function:"mean"}),
    {gt:"0.025",function:"min"}
composite-filter-min
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
