Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: integrate(set[])
Given an arbitrary number of series, performs a numerical integration on each series to return a set of equal length. This is equivalent to computing the cumulative sum over the series, where each point in the returned series is the sum of the current point and the accumulated sum of all previous points in the series.
Example:
The following expression plots the sum of AWS.EC2.CPUCreditUsage and all previous values of AWS.EC2.CPUCreditUsage which display in a given time period. The series in the example includes the optional fields period and function, which if removed will default to the metric’s native period and a summary statistic of mean.
integrate(
  sum(s("AWS.EC2.CPUCreditUsage",
    {"name": "prodvpc*"},
    { period:"60", function:"sum" }
The chart below demonstrates how the integration expression (provided above) starts at the actual value of the metric and continuously climbs at the rate of the next metric value provided.
integrate-example-1
You can see how the integrate stream continues to rise with each data point from the increase from AWS.EC2.CPUCreditUsage.
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
