Documentation forAppOptics
AppOptics will reach its End of Service Life on January 31, 2026. Migrate to the next generation APM solution as soon as possible to avoid disruption. See FAQ, or contact appopticsng-questions@solarwinds.com for support. Documentation is no longer being updated, and some features or links may not work as described.
Function: top(set[], options={})
The top method operates over the entire series across the given time-window. For each series returned in the set[] list, the method will compute the given function (as specified in the options) across all points in the window. The output of that function will be a scalar value and it is used to generate a ranking of each series. From that ranking the top function will return one to N series, where the series are ordered from highest to lowest rank value. The following options are supported:
  • count: how many series to return
  • function: a function that defines the ranking algorithm by which the streams should be selected. The permitted functions are: min, max, mean, and sum. The default function is mean.
Example
The following expression will return the top 10 streams for the system.cpu.user metric based on the maximum value in the observed time period.
top(s("system.cpu.user", {"@host":"*"}), {"count": "10","function": "max"})
func_top
Navigation Notice: When the APM Integrated Experience is enabled, AppOptics shares a common navigation and enhanced feature set with other integrated experience products. How you navigate AppOptics and access its features may vary from these instructions.
