Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Kiwi Syslog Server Installation and Upgrade Guide
SolarWinds strongly recommends that you install Kiwi Syslog Server on a server that is protected from unauthorized access by the public. If your use of Kiwi Syslog Server does not need to be public or internet-facing, install it on a server that is neither public, nor internet-facing. To learn about best practices for configuring your Kiwi Syslog Server installation securely, see Best practices to secure SolarWinds Products.
Kiwi Syslog Server is a syslog server for the Windows platform. It receives syslog messages and SNMP traps from network devices such as routers, switches, and firewalls. You can choose the newer recommended version, or the legacy version.
Kiwi Syslog Server NG
Kiwi Syslog Server NG is the newest generation of Kiwi Syslog Server that implements .NET frameworks for a more efficient and reliable user experience. Kiwi Syslog Server NG has also been overhauled and replaced with a new web-based UI.
To prepare your environment and install KSS NG, see the Kiwi Syslog Server NG Install Guide.
Download the PDF: Kiwi Syslog Server NG Install Guide PDF
Legacy Kiwi Syslog Server
You may also prepare and install the legacy version of Kiwi Syslog Server. See the legacy Kiwi Syslog Server Install Guide.
Download the PDF: Legacy Kiwi Syslog Server Install Guide PDF
