Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Kiwi Syslog Server Administrator Guide
Kiwi Syslog Server is a syslog server for the Windows platform. It receives syslog messages and SNMP traps from network devices such as routers, switches, and firewalls. You can choose the newer recommended version, or the legacy version.
Kiwi Syslog Server NG
Kiwi Syslog Server NG is the newest generation of Kiwi Syslog Server that implements .NET frameworks for a more efficient and reliable user experience. Kiwi Syslog Server NG has also been overhauled and replaced with a new web-based UI.
To further configure and customize KSS NG, see the Kiwi Syslog Server NG Administrator Guide.
Download the PDF: Kiwi Syslog Server NG Administrator Guide PDF
Legacy Kiwi Syslog Server
You may also further configure and customize the legacy version of Kiwi Syslog Server beyond the Getting Started Guide. See the legacy Kiwi Syslog Server Administrator Guide.
Download the PDF: Legacy Kiwi Syslog Server Administrator Guide PDF
Event Log Forwarder Guide
The purpose of this guide is to assist you in installing, configuring, and using the Kiwi Syslog Server Event Log Forwarder (ELF). Use the information in this guide to prepare your environment and begin using Event Log Forwarder. See the Event Log Forwarder Guide.
Download the PDF: Event Log Forwarder Guide PDF
