Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Enable a beep on every message — Legacy
This documentation is for an unsupported version.
If this option is enabled, Kiwi Syslog Server plays a beep when it receives any syslog message or SNMP trap. The beep will be heard even if a filter blocks the display or logging of the message. This option can be used for debugging to let you know that a message has been received.
If you are hearing a beep on every message that comes in and this option isn't checked then there is a problem logging the messages to disk. Check the Error log for details of the problem. (From the View menu). If a message can't be written to the specified log file, a beep will sound to notify you of the problem.
  1. Choose File > Setup to open the Kiwi Syslog Server Setup dialog box.
  2. Click the Inputs node.
  3. Select Beep on every message received.
  4. Click Apply to save your changes.
