Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Rename console displays and change display options — Legacy
This documentation is for an unsupported version.
Kiwi Syslog Server provides multiple displays that you can use to segment data. For example, you can create rules to log all messages to the default display but only high-priority messages to another display. You can give each display a more meaningful name, and specify other display options such as how many rows are shown.
  1. Select File > Setup.
  2. Click Display.
  3. To rename a display:
    1. Select the display under Modify display names.
    2. Enter the new name in the box on the right.
    3. Click Update.
      The menu on the left is updated.
  4. To change other display options, select or clear the associated check boxes.
    Except for display names, the changes you make affect all displays.
  5. Click Apply to save changes to the displays.
  6. Click OK.
