Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
KRDPIdleTimeout — Legacy
This documentation is for an unsupported version.
Use this Kiwi Syslog Server registry setting to specify the time the sending socket will remain connected after the last message has been sent. Because TCP has an overhead when connecting and disconnecting, the TCP connection will remain open for a time to allow any further messages to be sent without triggering a new connection. The idle timer starts as soon as a message has been sent. If no further messages have been sent in the time specified by KRDPIdleTimeout then the connection is closed.
Section (32-bit Windows OS) HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds\Syslogd\Properties
Section (64-bit Windows OS) HKEY_LOCAL_MACHINE\Software\WOW6432Node\SolarWinds\Syslogd\Properties
Value (STRING) KRDPIdleTimeout
Min value 0 (off)
Max value 65535
Default value 60
Type Seconds
