Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Configure UDP input options — Legacy
This documentation is for legacy Kiwi Syslog Server versions 9.8.3 and older. See the KSSNG version of Configure UDP input options for the newest version of the following documentation.
By default, Kiwi Syslog Server listens for UDP messages on port 514. You can configure UDP input options to change the port, bind to a specific interface, or specify a data encoding format.
  1. Choose File > Setup to open the Kiwi Syslog Server Setup dialog box.
  2. Expand the Inputs node.
  3. Click UDP.
  4. Specify the following options:
    Listen for UDP messages
    This option is selected by default to enable Kiwi Syslog Server to receive UDP messages.
    UDP Port
    The default port for UDP Syslog messages is 514. If you want to listen on a different port for UDP messages, you can enter any port value from 1 to 65535. If you change the port from 514, the device sending the syslog message must also be able to support the alternate port number.
    Kiwi Syslog Server can listen for messages on only one UDP port.
    Bind to address
    By default, the UDP socket will listen for messages on all connected interfaces. If you want to limit the binding to a single specific interface, you can specify the IP address in the Bind to address field. Otherwise, leave this field blank. (If the Bind to address field is left blank, it will listen on all interfaces. This is the best option in most cases.)
    For example, if you have two non-routed interfaces on the computer, 192.168.1.1 and 192.168.2.1, then you can choose to bind to only the 192.168.1.1 interface. This will ignore any syslog messages sent to the other interface.
    Data encoding
    If you are receiving messages from systems that use different data encoding formats, you can specify the decoding method to apply to the incoming data. The default is to use the System code page.
    Select a commonly used encoding format from the drop-down menu. Or, to select a different encoding, choose "Other-->" and then enter the code page number into the field on the right.
    The various code pages available on most Windows systems can be found on the Microsoft website. Here are some common code page numbers that can be used.
    Name
    Code Page
    Number
    Description
    System
    1
    System Code Page
    ANSI
    0
    ANSI
    UTF-8
    65001
    Format
    Unicode Transformation
    8Shift-JIS
    932
    Japanese
    EUC-JP
    51932
    Japanese Extended Unix Code
    BIG5
    950
    Traditional Chinese
    Chinese
    936
    Simplified Chinese
    If the number you specify is not a valid Code Page on your system, the incoming data will not be decoded correctly and will be dropped. If in doubt, use UTF-8 encoding (65001) as it will handle all Unicode characters.
  5. Click Apply to save your changes.
