Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Test a filter or action in KSS NG
Before enabling a rule in Kiwi Syslog Server NG (KSS NG), test the filters or actions to make sure they work as intended.
Test the filter or action setup dialog
When you add a filter or action, you can test your configuration.
  1. From the KSS NG navigation bar, choose Setup > Settings > Test Message.
  2. Select the protocol and complete the relevant fields for your test message. Click Apply.
  3. Once you have applied your changes, click Test.
    A green toast message will appear in the upper-right corner of the user display if the test message sends successfully.
Use the Kiwi SyslogGen utility
You can test filters and actions using Kiwi SyslogGen, a free utility that generates and sends syslog messages. You can specify message properties such as priority, message text, and sending IP address.
  1. Go to the Kiwi Syslog Free Products and Utilities page and download Kiwi SyslogGen.
  2. Install Kiwi SyslogGen on the computer where KSS NG is installed.
  3. Use Kiwi SyslogGen to generate messages that meet the filter criteria, and verify that the results are what you intended.
