Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Script variables used in KSS NG
Fields, a globally accessible object, passes variables to and from the script. Variables are used to store data values you receive from messages in Kiwi Syslog Server NG (KSS NG). See Use variables in a script for reference.
The current version of KSS NG only supports PowerShell scripts.
Depending on the read/write permissions you set for the action, the variables can be modified and returned for use in the syslog program.
Use the following variables for scripts in KSS NG.
Common variables
Display name Variable name Description Variable type Example
VarFacility $Common.VarFacility The facility value of the message. Integer (0-32767) 19
VarLevel $Common.VarLevel The level value of the message. Integer (0-32767) 7
VarInputSource $Common.VarInputSource The message input source. Integer (0-32767) 4
VarPeerAddress $Common.VarPeerAddress The IP address of the sending device in nnn.nnn.nnn.nnn format. If another syslog collector forwards the message, this value contains the original sender's address. String 192.168.1.67
VarPeerName $Common.VarPeerName If you enable DNS lookup options and a lookup is successful, this field only contains a resolved host name. Otherwise, this field contains the same value as VarPeerAddress in the format. String myhost
VarPeerDomain $Common.VarPeerDomain The domain name of the resolved FQDN. This is the domain suffix. It does not contain the host name. String http://mydomain.com
VarCleanMessageText $Common.VarCleanMessageText The modified message text (for example, header removed, DNS lookups, original address removed, and Cisco date removed). String SEC-6-IPACCESSLOGP: list 101 denied udp 10.0.0.3 (firewall) (137) -> 216.7.14.105 (webserver.company. com) (137), 1 packet
Other variables
VarDate $Other.VarTime The date the message was received by the syslog program. String (10 bytes) 2022-12-31
VarTime $Other.VarTime The time the message was received by the syslog program. String (8 bytes) 23:10:04
VarMilliSeconds $Other.VarSocketPeerAddress The time the message was received by the syslog program, in milliseconds past the second. String (3 bytes) 099
VarSocketPeerAddress $Other.VarSocketPeerAddress The IP address of the device, or the closest syslog collector, that sent the message. String 192.168.1.67
VarPeerAddressHex $Other.VarPeerAddressHex The IP address of the device that sent the message converted to an 8 digit hex value. String (8 bytes) C0A80102
VarPeerPort $Other.VarPeerPort The UDP/TCP port that the message was sent from. Integer (0-65535) 65535
VarLocalAddress $Other.VarLocalAddress The IP address that the message was sent to on this machine. String 192.0.2.0
VarLocalPort $Other.VarLocalPort The local machine UDP/TCP port that received the message. Integer (0-65535) 191
VarPriority $Other.VarPriority The message priority value. Integer (0-32767) 65535
VarRawMessageText $Other.VarRawMessageText The message as it was received before modification (includes <pri> tag, original address, and so on). String $Other.VarRawMessageText
Global variables
<UserDefinedName> $Global.<UserDefined> Variable to be set in scripts that are executed on each syslog/trap message. (The system does not erase static values with each new message like the other script fields) String $Custom.<UserDefined>
Custom variables
<UserDefinedName> $Custom.<UserDefined> Variable to be set in scripts that are executed on each syslog/trap message. String $Custom.<UserDefined>
