Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
AutoSplit values — Legacy
This snippet is used for legacy 9.8.3 topics that link to a KSS NG topic of the same name.
When you add an action to log messages to a file, place an AutoSplit value in the path or file name to automatically split the log files. When a message is received, the variable is replaced with a value from the message.
AutoSplit values can be used anywhere within the path or log file name, as long as the result is a valid file name. Any number of AutoSplit values can be used within the path or file name.
If you are using the Run Script action, you can use any of the configured VarCustom or VarGlobal fields as an AutoSplit value. The following sections describe the available options.
Examples:
  • To split the messages into separate files based on the day of the month:
    C:\Logs\MyLogFile%DateD2.txt
    The %DateD2 is replaced by the current day of the month. On the 23rd of the month, the message is written to:
    C:\Logs\MyLogFile23.txt
  • To split the messages based on priority level and current date:
    C:\Logs\%PriLevAA\MyLogFile-%DateISO.txt
    On April 9, 2016, the path and file name look like this:
    C:\Logs\Debug\MyLogFile-2016-04-09.txt
  • To split the messages based on the sending host, and then by priority level:
    C:\Logs\%HostName.%HostDomain\MyLogFile-%PriLevAA.txt
    The path and file name look like this:
    C:\Logs\myhost.mycompany.com\MyLogFile-Debug.txt
Date values
Menu name ISO Date (YYYY-MM-DD)
Parameter %DateISO
Explanation International formatted date in the format YYYY-MM-DD. Leading zeros, always 10 characters in length.
Example 2017-10-15
Menu name Year (YYYY)
Parameter %DateY4
Explanation 4 digit year, always 4 characters in length
Example 2017
Menu name Year (YY)
Parameter %DateY2
Explanation 2 digit year, always 2 characters in length
Example 17
Menu name Month (MM) with leading zero
Parameter %DateM2
Explanation 2 digit month with leading zero, always 2 characters in length
Example 12
Menu name Month (MMM) in English
Parameter %DateM3
Explanation 3 character month in English, always 3 characters in length. First letter is in upper case.
.Example Nov
Menu name Date (DD) with leading zero
Parameter %DateD2
Explanation 2 digit day of the month with leading zero, always 2 characters in length
Example 05
Menu name Day (DDD) in English
Parameter %DateD3
Explanation 3 character day of the week in English, always 3 characters in length. First letter is in upper case.
Example Fri
Time values
Menu name Hour (HH) with leading zero
Parameter %TimeHH
Explanation 2 digit hour, always 2 characters in length. 24 hour display. 3 p.m. = 15
Example 14
Menu name Minute (MM) with leading zero
Parameter %TimeMM
Explanation 2 digit minute, always 2 characters in length
Example 59
Menu name AM/PM indicator (AM or PM)
Parameter %TimeAMPM
Explanation 2 character time of day indicator. Always 2 characters in length. 00:00 to 11:59 = AM. 12:00 to 23:59 = PM
Example AM
Priority values
Menu name Level (Alpha)
Parameter %PriLevAA
Explanation The message priority level as a word: Debug, Notice, Info…
Example Critical
Menu name Facility (Alpha)
Parameter %PriFacAA
Explanation The message priority facility as a word: Local1, News, Cron…
Example User
Menu name Level (2 digit numeric)
Parameter %PriLev00
Explanation The message priority level as a 2 digit number: 00 to 07
Example 05
Menu name Facility (2 digit numeric)
Parameter %PriFac00
Explanation The message priority facility as a 2 digit number: 00 to 23
Example 23
Menu name Priority (3 digit numeric)
Parameter %Pri000
Explanation The message priority as a 3 digit number: 000 to 191
Example 016
IP Address values (Licensed edition only)
Menu name IP Address (4 octets, zero padded)
Parameter %IPAdd4
Explanation The IP address of the device that sent the message. Each octet is zero padded. Always 15 characters in length
Example 192.168.001.024
Menu name IP Address (3 octets, zero padded)
Parameter %IPAdd3
Explanation The first 3 octets of the IP address of the device that sent the message. Each octet is zero padded. Always 11 characters in length.
Example 192.168.001
Menu name IP Address (2 octets, zero padded)
Parameter %IPAdd2
Explanation The first 2 octets of the IP address of the device that sent the message. Each octet is zero padded. Always 7 characters in length.
Example 203.056
Menu name IPv6 Address
Parameter %IPv6Add6
Explanation The IPv6 address of the device that sent the message. IPv6 address of the device is separated with ~ as special character is not accepted in file name.
Example ABC~567~0~0~8888~9999~1111~0
Host name values (Licensed edition only)
Menu name Hostname (no domain name)
Parameter %HostName
Explanation The host name of the device that sent the message. No domain name is included.
Example sales-router
Menu name Domain (no host name)
Parameter %HostDomain
Explanation The domain name suffix of the device that sent the message. No host name is included.
Example mycompany.co.nz
Menu name Reversed domain (no host name)
Parameter %HostDomRev
Explanation The domain name suffix of the device that sent the message, in reverse order. No host name is included.
Example nz.co.mycompany
Message Text - WELF format (Licensed edition only)
WELF format is the WebTrends Extended Logging Format. This format is used by firewalls such as GNATBox, SonicWall, CyberWallPlus, and NetScreen. Each field within the message text is prefixed with an identifying tag, such as fw= for the firewall name or src= for the source of the packet being logged.
Menu name Firewall name (WELF format)
Parameter %TextFW
Explanation The name of the firewall that created the message
Example protector
Menu name Source address (WELF format)
Parameter %TextSrc
Explanation The source IP address of the packet being logged by the firewall (not zero padded, unless this has been done by the firewall already)
Example 192.168.1.6
Menu name Destination address (WELF format)
Parameter %TextDst
Explanation The destination IP address of the packet being logged by the firewall (not zero padded, unless this has been done by the firewall already)
Example 203.57.12.1
Menu name Protocol (WELF format)
Parameter %TextProto
Explanation The protocol of the packet being logged by the firewall
Example http
Menu name Serial Number (WELF format)
Parameter %TextSn
Explanation The Serial number of the device as in WELF Message
Example abcdDDDXSD
Input Source values (Licensed edition only)
Menu name Input Source (UDP/TCP/SNMP)
Parameter %InpSrc
Explanation Identifies the input source of the message. (The listening method that received the message)
Example UDP
Custom/Global script fields (Licensed edition only)
Menu name VarCustom01 to VarCustom16
Parameter %VarCustom01 to %VarCustom16
Explanation There are 16 custom fields that can be modified by the Run Script action. If these fields have not been modified by the script, they are blank. Be aware that a blank autosplit value may result in an invalid file name. The custom field values are cleared when a new message arrives. They are only valid for the current message. To store values longer than a single message, use VarGlobal fields.
Example Any value that the script creates can be used.
Menu name VarGlobal01 to VarGlobal16
Parameter %VarGlobal01 to %VarGloabl16
Explanation There are 16 global fields that can be modified by the Run Script action. If these fields have not been modified by the script, they are blank. Be aware that a blank autosplit value may result in an invalid file name. The global fields retain their value between messages.
