Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Filter messages based on priority in KSS NG
Each incoming message contains a priority value, which consists of a facility and a severity level. Use the Priority filter to trigger an action when you receive high or low priority messages. For example, you can create a rule that sends an email when you receive a message with a critical or higher priority level.
If a rule does not contain a Priority filter, Kiwi Syslog Server NG (KSS NG) includes all priorities by default.
  1. From the KSS NG navigation bar, choose Setup > Rules.
  2. Locate an existing rule. If the rule does not exist, add a rule and start the New Rule wizard.
  3. If you are adding a filter to an existing rule, select the rule and click Edit. If you are creating a new rule, navigate to the Filters step of the New Rule wizard.
  4. Click Add filter. Define the filter name in the provided field.
  5. In the Field drop down, select Priority.
  6. Select the Facility and Severity values in their respective drop downs.
  7. If you are adding a filter to an existing rule, click Apply. If you are creating a filter in the New Rule wizard, click Add.
Only messages with the priorities you select trigger the actions in the associated rule.
