Documentation forKiwi Syslog Server
Legacy KSS reached its End of Service Life on March 28, 2026. Users should migrate to the next generation of KSS. See the release history for the latest version.
Configure devices to send messages to Kiwi Syslog Server — Legacy
This snippet is used for legacy 9.8.3 topics that link to a KSS NG topic of the same name.
To receive messages from a syslog-capable device, configure the device to send syslog messages to the appropriate port on the computer where Kiwi Syslog Server is installed.
Kiwi Syslog Server automatically listens for UDP messages on port 514. This is the default port for devices sending syslog messages as defined by the RFC standard 5426.
You can configure Kiwi Syslog Server to listen for UDP message on a different port. You can also enable Kiwi Syslog Server to listen for TCP messages, secure TCP messages, and SNMP traps.
For information about configuring a specific device, see documentation from the device manufacturer. See an example of configuring a Cisco switch.
Message logging must be enabled on the device. On many devices that generate syslog messages, logging is enabled by default.
If you have configured devices but Kiwi Syslog Server is not displaying messages, see troubleshooting tips.
