Documentation forNetFlow Traffic Analyzer
Custom NetFlow views
The Flow Navigator allows you to create custom NetFlow views.
You can apply filters on all monitored objects, called summary filtered views, or you can specify objects that you want to filter further, called detail filtered views.
All views filtered by a node display only Ingress or Egress data in order to maintain the current performance level. If you select Both, the default setting for the view is applied instead.
The following sections provide specific information about custom filtered traffic views using the Flow Navigator.
