Documentation forNetFlow Traffic Analyzer
Flows per Second statistics
With NTA, you can view Flows Per Second statistics for nodes. The feature is available only through the SolarWinds Information Service (SWIS). You can create reports for the Flows per Second statistics using SWQL studio or through the entity NetFlow Node Sources in the SolarWinds Platform Web Console:
  1. In the SolarWinds Platform Web Console, click Reports > All reports.
  2. In the Group by drop-down, select Product > click NTA Reports > click NetFlow Sources.
  3. Click Edit report.
  4. On the Edit Report page (Layout builder tab), under Content, click Edit table.
  5. On the Edit Resource page, under Table layout, click + to add a new column.
  6. Click NetFlow Node Statistic, and select one or more of the following:
    • Flows Per Second Last 24 Hours: Displays the Flows per Second statistics for nodes for the last 24 hours.
    • Flows Per Second Last 3 Days: Displays the Flows per Second statistics for nodes for the last three days.
    • Flows Per Second Last 5 Minutes: Displays the Flows per Second statistics for nodes for the last five minutes.
