Edit flow direction in NTA views
You can customize the flow direction shown by all appropriate widgets on a view. These settings are limited to the current session. Once you leave the view, all widgets will show default flow direction settings.
Change flow direction in a view
- Click
next to the flow direction setting below the view name. - Select a flow direction: Both, Ingress, or Egress. The Select Flow Direction menu only provides the options that can be applied to the current view.
- Click Submit.
