NTA Settings
Each of the following sections provides instructions for configuring NTA and customizing it to meet your network analysis requirements.
Access the NetFlow Traffic Analyzer Settings page
                                    In the SolarWinds Platform Web Console, click Settings > All Settings.
                                    Under Product Specific Settings, click NTA Settings.
Available settings
The configuration actions described in the following sections require administrative access to the SolarWinds Platform Web Console.
                                    NetFlow management: Configure default behavior when flows from NPM devices are received, towards data from ports not monitored in NTA, and unmanaged interfaces.
                                    Application and service ports: Configure the ports and applications that should be monitored in NTA.
                                    Autonomous systems: Manage autonomous systems monitored in NTA.
                                    IP address groups: Manage IP address groups and select IP groups whose traffic should be monitored in NTA.
                                    Monitored protocols: Select what protocols you want to monitor in NTA.
                                    Flow sources and CBQoS polling management: Select what flow sources and which CBQoS-enabled devices you want to monitor with NTA.
                                    NetFlow collector services: Add or change ports on which the NetFlow service is listening.
                                    Types of services: Change names used for DiffServ Code Points in NTA.
