Documentation forNetFlow Traffic Analyzer
Required fields in SolarWinds NTA
Most flow-enabled devices use a set of static templates to which exported flows conform.
If flow packets do not include the following field types and appropriate values, NTA ignores the packets.
Requirements
  • The template must include all mandatory fields.
  • Where multiple elements are in a group, at least one of them must be included.
  • Optional fields are processed into flows if present. If not present, a default value is used.
For more information about fields required for sampled flows, see Sampled flow supported fields.
For more information about supported flow protocols, see NTA flow requirements.
Mandatory fields for the flow template schema
Mandatory fields are required. If a mandatory field, or at least one field from a group, is not included NTA cannot store flows.
Field Type Field Type Number Description
Protocol 4 Layer 4 protocol
SourceAddress 8, 27 Source IP address or source IPv6 address
DestAddress 12, 28 Destination IP address or destination IPv6 address
Interfaces Group
At least one of the following fields must be included in the template.
InterfaceRx 10 SNMP ingress interface index
InterfaceTx 14 SNMP egress interface index
Bytes Group
Bytes 1 Delta bytes
Bytes 85 Total bytes
OutBytes 23 Out bytes
InitiatorOctets 231 Initiator bytes
ResponderOctets 232 Responder bytes
Optional fields for the flow template schema
If the following fields are not included in the template, a default value will be stored. Appropriate widgets will thus show No Data.
ToS 5 Type of service
SourceAS 16 Source BGP autonomous system number
DestAS 17 Destination BGP autonomous system number
PeerSrcAS 129 Peer source autonomous system number
PeerDstAS 128 Peer destination autonomous system number
ApplicationID 95 ID of application detected in NBAR2 flow
Source Port Group
At least one of the following fields should be included in the template.
SourcePort 7 Source TCP/UDP port
UdpSrcPort 180 Source UDP port
TcpSrcPort 182 Source TPC port
Destination Port Group
DestPort 11 Destination TCP/UDP port
UdpDstPort 181 Destination UDP port
TcpDstPort 183 Destination TPC port
Packets Group
At least one of the following fields should be included in the template. If no field is included, widgets will show 0 in the packets column.
Packets 2 Delta packets
Packets 86 Total packets
OutPackets
24
Out packets
InitiatorPackets 298 Total packets in a flow from the device that triggered the session and remains the same for the life of the session
ResponderPackets 299 Total packets from the device which replies to the initiator
Long Flow Detection
At least one of the following field pairs should be included in the template for long-flow detection. For example, if including LastSwitched must also include FirstSwitched.
LastSwitched 21 System uptime at which the last packet of this flow was switched
FirstSwitched 22 System uptime at which the first packet of this flow was switched
FlowStartSeconds 150 Time in seconds that the flow started
FlowEndSeconds 151 Time in seconds that the flow ended
FlowStartMilliseconds 152 Time in milliseconds that the flow started
FlowEndMilliseconds 153 Time in milliseconds that the flow ended
FlowStartMicroseconds 154 Time in microseconds that the flow started
FlowEndMicroseconds 155 Time in microseconds that the flow ended
FlowStartNanoseconds 156 Time in nanoseconds that the flow started
FlowEndNanoseconds 157 Time in nanoseconds that the flow ended
FlowStartDeltaMicroseconds 158 Sets the start delta of the flow
FlowEndDeltaMicroseconds 159 Sets the end delta of the flow
FlowDurationMilliseconds 161 Elapsed time in milliseconds of the flow
FlowDurationMicroseconds 162 Elapsed time in microseconds of the flow
Cisco WLC Flows
The following fields must be included for Cisco Wireless devices.
Bytes 1 Total bytes
Packets 2 Total packets
FlowDirection 61 Direction of the flow defined as Ingress or egress.
ApplicationID 95 ID of application detected in flow
WlanSSID 147 Service Set Identifier or name of the WLAN the wireless device is connected to
WirelessStationMacAddress 365 MAC address of a wireless device
WirelessAPMacAddress 367 MAC address of a wireless access point
PostIPDiffServCodePoint
This field is optional.
98
The definition of this Information Element is identical to ipDiffServCodePoint, except that it reports a potentially modified value caused by a middlebox function after the packet passed the Observation Point.
IPDiffServCodePoint
195
Value of a Differentiated Services Code Point (DSCP) encoded in the Differentiated Services field. Differentiated Services field is the most significant six bits of the IPv4 TOS FIELD or the IPv6 Traffic Class field.
The value may range from 0 to 63 for this Information Element that encodes only the 6 bits of the Differentiated Services field.
Cisco WLC Flows
WirelessStationAddressIPv4 366 IPv4 address of a wireless device
IPv4SourceAddress 8 Source IPv4 address
IPv4DestinationAddress 12 Destination IPv4 address
Cisco ASA devices
The following fields must be included for processing flows from Cisco ASA devices.
FlowID 148 An identifier of a flow that is unique within an observation domain.
FirewallEvent 233 Indicates a firewall event.
NAT Group
The following fields must be included for NAT stitching
Post-NAT Source IPv4 225 Source IP address for Network Address Translation (NAT).
Post-NAT Destination IPv4 226  Destination IP address for Network Address Translation (NAT).
Post-NAT Source Port 227 Source port for Network Address Translation (NAT).
Post-NAT Destination Port 228 Destination port for Network Address Translation (NAT).
Notes
  • If SolarWinds states that NTA supports flow monitoring for a device, at least one of the templates that the device exports satisfies these requirements.
  • The NetFlow v9 specification indicates that templates may be configurable on a device-by-device basis. However, most devices have a set of static templates to which exported flows conform. When SolarWinds states that a device is supported by NTA, SolarWinds has determined that at least one of the templates the device is capable of exporting will satisfy the NTA requirements. For more information, search for NetFlow version 9 flow record format on www.cisco.com.
  • Cisco 4500 series switches do not provide information for the TCP_FLAGS field (field type number 6) corresponding to a count of all TCP flags seen in the related flow.
  • Cisco Adaptive Security Appliances (ASA) are capable of providing flow data using a limited template based on the NetFlow v5 template.
