Set up NBAR2 on Cisco devices
Network Based Application Recognition (NBAR) is the mechanism used by certain Cisco routers and switches to recognize a dataflow by inspecting some of the packets sent. NTA 2026.4.1 supports unknown traffic detection and advanced application recognition through NBAR2.
First, configure your Cisco devices to send NBAR2 data to NTA. Second, add those devices as nodes in NPM and NTA.
The following values are examples used in the commands below:
- NTArec
- NTAexp
- NTAmon
- GigabitEthernet0/1
- 10.10.10.10
Create a new Flexible NetFlow configuration
Add the flow record
This process is similar to creating a standard NetFlow configuration. In this case, you add the collect application name command to enable the sending of AppID in each flow.
flow record NTArec match ipv4 tos match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match interface input collect interface output collect counter bytes collect counter packets collect application name exit
Add the flow exporter
The option application-table command enables the sending of a list of applications that can be classified using NBAR2, including applications that were manually created. The option application-attributes command enables the sending of categories for all applications.
flow exporter NTAexp destination 10.10.10.10 source GigabitEthernet0/1 transport udp 2055 export-protocol netflow-v9 template data timeout 60 option application-table timeout 60 option application-attributes timeout 300 exit
Add the flow monitor
The flow monitor connects the flow recorder and the flow exporter. You can configure multiple recorders, exporters, and monitors at once.
flow monitor NTAmon description NetFlow nbar record NTArec exporter NTAexp cache timeout inactive 30 cache timeout active 60 exit
When receiving long flows, these values may need to be adjusted, see Troubleshoot Long Flow Errors in NTA for more details. For more information about the timeout values, refer to the Cisco NetFlow Command Reference.
Apply the monitor to an interface
Assign the Flexible NetFlow configuration to the interface from which to monitor NetFlow.
interface GigabitEthernet0/1 ip flow monitor NTAmon input ip flow monitor NTAmon output exit
Diagnostic commands
show flow record "recordName" show flow export "exporterName" show flow monitor "monitorName" show flow exporter statistics show flow interface
Determine the applications your device can recognize
The Protocol Pack is a list of applications, definitions, and categories that your device can recognize.
Check the Protocol Pack version
show ip nbar version
View a list of the available applications
show ip nbar protocol-id
Edit an existing record
If you edit an existing record that is in use, you receive the following error:
% Flow Record: Flow Record is in use. Remove from all clients before editing.
To resolve this error, remove the connection between the monitor, record, and interface.
Disable the connection
interface GigabitEthernet0/1 no ip flow monitor NTAmon input no ip flow monitor NTAmon output exit
Add the application recognition field into the record
flow record NTArec collect application name exit
Add the application recognition field into the exporter
flow exporter NTAexp option application-table timeout 60 option application-attributes timeout 300
Restore the connection
