NTA flow requirements
NTA supports the following flow protocols:
| Flow | Supported Versions | Sampled Flow Support |
| NetFlow |
v1, v5, and v9 NetFlow v9 must have an appropriate template with all required fields. |
v5 and v9 Some devices using IOS versions export flows without specifying that it is being sampled. NTA processes these flows as unsampled. |
| sFlow | v2, v4, and v5 | Supported |
| J-Flow | Supported |
Supported Some devices using JunOS versions export flows without specifying that it is being sampled. NTA processes these flows as unsampled. |
| IPFIX |
IPFIX (v10) supported for networks running on IPv4 |
Supported |
| NetStream | v5 and v9 | Supported |
| NetFlow Lite |
Supported on the following devices:
Supported |
| Cisco Wireless Controller NetFlow |
Supported on the following devices with the ipv4_client_app_flow_record template:
Not supported
Difference between sampled and non-sampled flow:
- Sampled flow: Collects less data and provides only a sample. This prevents the network from overloading.
- Non-sampled flow: Collects all data.
For information about required fields for the flow template schema, see Required fields in SolarWinds NTA.
