Documentation forNetFlow Traffic Analyzer
Extreme sFlow configuration
To support Extreme devices, you must configure the device using the following configuration template.
Scripts are not supported under any SolarWinds support program or service. Scripts are provided AS IS without
warranty of any kind. SolarWinds further disclaims all warranties including, without limitation, any implied warranties
of merchantability or of fitness for a particular purpose. The risk arising out of the use or performance of the scripts
and documentation stays with you. In no event shall SolarWinds or anyone else involved in the creation, production, or
delivery of the scripts be liable for any damages whatsoever (including, without limitation, damages for loss of business
profits, business interruption, loss of business information, or other pecuniary loss) arising out of the use of or
inability to use the scripts or documentation.
enable sflow
configure sflow config agent 10.199.5.10
configure sflow collector 192.168.72.67 port 2055
configure sflow sample-rate 128
configure sflow poll-interval 30
configure sflow backoff-threshold 50
enable sflow backoff-threshold
enable sflow ports all
The sFlow collector value must reflect the IP address of your NPM server. This value also contains the port number (2055) that is required in this step.
