Documentation forNetFlow Traffic Analyzer
Cisco Flexible NetFlow configuration
Exporting flows on some Cisco devices (for example, the 4500 series, with Supervisor 7) requires using Flexible NetFlow. This configuration example successfully exports flows from a Cisco 4507 with Supervisor 7:
Scripts are not supported under any SolarWinds support program or service. Scripts are provided AS IS without
warranty of any kind. SolarWinds further disclaims all warranties including, without limitation, any implied warranties
of merchantability or of fitness for a particular purpose. The risk arising out of the use or performance of the scripts
and documentation stays with you. In no event shall SolarWinds or anyone else involved in the creation, production, or
delivery of the scripts be liable for any damages whatsoever (including, without limitation, damages for loss of business
profits, business interruption, loss of business information, or other pecuniary loss) arising out of the use of or
inability to use the scripts or documentation.
flow record ipv4
! match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes
collect counter packets
flow exporter NetFlow-to-Orion
destination 10.10.10.10
source vlan254
transport udp 2055
export-protocol netflow-v5
flow monitor NetFlow-Monitor
description Original Netflow captures
record ipv4
cache timeout inact 10
cache timeout act 5
vlan configuration 666
ip flow monitor NetFlow-Monitor input
The flow exporter destination and transport udp values must reflect the IP address and port (2055) of your NPM server.
NTA supports NetFlow version 5 and version 9. For more information about NetFlow version 5 or 9, see your Cisco router documentation or the Cisco website at www.cisco.com (© 2021 Cisco, available at https://www.cisco.com/, obtained on July 15th, 2021).
