Documentation forNetFlow Traffic Analyzer
Disable flow sources and CBQoS-enabled devices
You can disable NetFlow and CBQoS monitoring through the NTA Settings in the SolarWinds Platform Web Console.
  1. In the SolarWinds Platform Web Console, click Settings > All Settings.
  2. Under Product Specific Settings, click NTA Settings.
  3. Click Flow Sources Management.
    You can also access the Flow sources management page by clicking My Dashboards > NetFlow > Flow Sources.
  4. Use the Filters to find the devices to display.
  5. Locate the interface you want to delete.
  6. Select flow sources, and click Drop traffic.
    If you disable NetFlow monitoring for a node or interface, the data stop being collected. However, historical data are kept in the database. Enabling and disabling flow collection can thus result in gaps in NTA graphs.
Disable CBQoS-enabled devices
  3. Under CBQoS Polling Management, click Manually manage CBQoS polling.
    You can also access the CBQoS polling management page by clicking My Dashboards > NetFlow > CBQoS Polling.
  5. Locate the interface you want to disable.
  6. Select CBQoS sources, and click Disable.
