Sampled flow supported fields
If you are using sampled flows, packets need to contain not only the fields mentioned in Required fields in SolarWinds NTA, but also fields supported by NTA for sampled flows. Supported fields depend on the flow version used.
Sampling mode has to be non-zero, otherwise NTA processes flows as non-sampled.
If some of the required fields are missing on your device or contain unexpected values, please contact your device vendor.
NetFlow v5 and J-Flow v5 header format
NTA supports the following bytes in the v5 header format:
| Bytes | Contents | Description |
| 22-23 | sampling_interval | First two bits hold the sampling mode; remaining 14 bits hold value of sampling interval. |
For more information, search for NetFlow export datagram format on www.cisco.com.
NetFlow v9 and J-Flow v9
Supported fields depend on the template you are using:
- Flow template
- Option template
Flow template
The following fields are optional for the Flow Template Schema. It is enough if the template includes one of the fields in each group.
If at least one from each group is not included in the template, NTA will still be able to store flows. However, a default value will be stored, and appropriate widgets will show the "No Data" message.
| Field Type | Field Type Number | Description |
Sampling Interval Group |
| SamplingInterval | 34 | When using sampled NetFlow, the rate at which packets are sampled, for example, a value of 100 indicates that one of every 100 packets is sampled. |
| SamplerInterval | 50 | Packet interval at which to sample. |
Sampling Algorithm Group |
| SamplingAlgorithm | 35 | The type of algorithm used for sampled NetFlow: 0x01 Deterministic Sampling, 0x02 Random Sampling |
| SamplerMode | 49 | The type of algorithm used for sampling data: 0x02 random sampling. |
Option template
Mandatory fields
If you are using the Option Flow Template, make sure at least one field from each group is included. Otherwise, flow data cannot be stored.
| SamplerInterval | 34 | Packet interval at which to sample. |
| SamplingAlgorithm | 35 | The type of algorithm used for sampled NetFlow: 0x01 Deterministic Sampling, 0x02 Random Sampling. |
| SamplerMode | 35 | The type of algorithm used for sampling data: 0x02 random sampling. |
SamplerID If the SamplerID isn't included in the options flow template, a default value will be stored, and appropriate widgets will display "No Data". |
| SamplerID | 48 | Identifier shown in show flow-sampler. |
For more information, search for NetFlow version 9 flow record format.
