Documentation forNetFlow Traffic Analyzer
Filter events and display historical events in NTA
You can view your events in the Last XX Traffic Analyzer Events widget which is available on all NetFlow summary views.
If you want to adjust the number of events to display or want to display only certain events, you can do so on the Events view.
If you want to see only unknown traffic events, click NetFlow Settings in any NetFlow view, and Under NetFlow Management click Show Unknown Traffic Events. For more information about unknown traffic, see Resolve unknown NetFlow traffic.
Filter all events
  1. Click Alerts & Activity > Events.
  2. You can further filter events by:
    1. Network Object or Type of Device
    2. Event Type
      The table below provides event types relevant for NTA events, and the corresponding events.
    3. Time Period
  3. If you want to see cleared events, select Show Cleared Events.
  4. If desired, edit the Number of Displayed Events.
  5. Click Refresh.
Event Type Events
NetFlow Receiver Service Started
NetFlow Receiver Service Settings Changed
NetFlow Receiver Service Stopped
License Limitation
No Valid License
Unmanaged NetFlow Node Unmanaged NetFlow Node
Unmonitored NetFlow Interface Automatically Added
NetFlow Event
NetFlow Event Interface Index Mapping Is Being Used for Node
NetFlow Event: Removing Interface Index Mapping for Node
NetFlow Database Maintenance
Scheduled Shrink Performed
Updating Data to Be Used in Top XX Aggregated widgets
Windows Firewall Is Turned on
Unmanaged NetFlow Interface Unmanaged NetFlow Interface
Invalid Template
Invalid Template
Invalid IPFIX Template
No Template Received No Template Received
Unsupported Incoming Flow Unsupported Incoming Flow
Not Enabled NetFlow Data Export Not Enabled NetFlow Data Export
ICMP NetFlow Node ICMP NetFlow Node
Not Primary NPM Node IP Address Not Primary NPM Node IP Address
Notification Reset
Notification Event Status Reset
NetFlow Licensing NetFlow Licensing
Informational
Unable to Start Listening on Port
Port Is Free, Listening
NetFlow service time difference warning
NetFlow service time difference warning ended
NetFlow service time difference error NetFlow Service time difference error
