Documentation forNetFlow Traffic Analyzer
Add NetFlow widgets to web console views
  1. In the SolarWinds Platform Web Console, click Settings > All Settings.
  2. Under Views, click Manage Dashboards/Views.
  3. In the list of views, select a NetFlow view to which you want to add a NetFlow-specific widget, and click Edit.
  4. Click + next to the column in which you want the new widget to be placed.
  5. In the Group By list, select Classic category.
  6. Select a NetFlow entry in the list.
  7. Select one or more widgets, and then click Add Selected Resources.
  8. Use the arrow buttons to move the widgets listed in the column into the order you want displayed in the SolarWinds Platform Web Console.
  9. Click Done.
For more information about using your customized view as a default view assigned to a user, see Editing User Accounts .
To add your customized view to a menu bar as a custom item, see Customizing Web Console Menu Bars.
