Enable NetFlow on Cisco Catalyst 4500 Series
The following sections provide the procedures required to enable NetFlow and NetFlow export to NetFlow Traffic Analyzer from the Catalyst 4500 Series.
This information is provided as a guide for enabling NetFlow to work with NTA. Consult your Cisco product documentation for details about configuring NetFlow on Cisco Catalyst 4500 Series devices.
Enable NetFlow to work with NTA
The Catalyst 4500 platform requires a NetFlow Services Card installed to enable NetFlow.
- Configure your switch for IP routing.
- Log in to the switch, and then enter global configuration mode.
-  Enter ip flow ingress infer-fieldsto enable NetFlow for IP routing with inferred input/output interfaces and source/destination border gateway protocol (BGP) as information.You must enable the infer-fieldsoption to determine any autonomous system information.
Configure the NTA server as a NetFlow destination
- Log in to the switch and enter global configuration mode.
- Type ip flow-export destination {hostname | ip-address} udp-portto direct exported NetFlow data to NTA, as in this example, where NTA is hosted on TAHost:ip flow-export destination TAHost 2055If you need to send data to more than one destination, you can specify up to two different destinations using successive calls of this command.
- Type ip flow-export version 5|9 {origin-as | peer-as}to set the NetFlow version for use with NTA.- Select - origin-asto direct NetFlow to determine the origin BGP autonomous system of both the source and the destination hosts of the flow, as in:- ip flow-export version 5|9 origin-as
- Select - peer-asto direct NetFlow to determine the peer BGP autonomous system of both the input and output interfaces of the flow, as in:- ip flow-export version 5|9 peer-as
- Type ip flow-export source interfaceto specify the interface that provides the source IP address in the IP header of the NDE packet. The default is the NDE output interface.
Display the NetFlow configuration for verification
- Enter privileged EXEC mode on your switch.
- Type show ip flow exportto display statistics and cache contents for your NetFlow configuration.
