Documentation forNetFlow Traffic Analyzer
Default flow direction for widgets in NTA
By default, all widgets in node detail views and interface detail views present data for ingress flows and SolarWinds Platform summary views present data for both flow directions.
You can configure the flow direction for any widget individually.
  1. In the SolarWinds Platform Web Console, click Settings > All Settings.
  2. Under Product Specific Settings, click NTA Settings.
  3. Scroll down to the Charting and Graphing Settings section.
  4. Select the desired direction from the Default flow direction for widgets placed on Summary views drop-down.
  5. Select the desired direction from the Default flow direction for widgets placed on Node Detail views drop-down.
  6. Select the desired direction from the Default flow direction for widgets placed on Interface Detail views drop-down.
  7. Select the desired direction from the Default flow direction for CBQoS widgets drop-down.
