Cisco Meraki
Add Meraki Organizations to NPM as external nodes, poll information from the cloud and display polled data in the SolarWinds Platform Web Console.
Monitored metrics
Meraki Wireless infrastructure provides centralized management of end devices, such as wireless devices, switches, or security appliances, as a cloud service. Physical devices act as thin Access Points (APs), managed by the cloud system. Physical devices are installed at physical locations and assigned to customers.
In NPM, Meraki Wireless objects are mapped to wireless entities.
Meraki Wireless How do you see the objects in SolarWinds Platform?
Organization Controller
Access Point Thin Access Point
Client Client
Metrics with limited support
  • SSID information: SolarWinds Observability Self-Hosted only polls SSID information for access points to which clients are connected.
Requirements
Add your Meraki Organization for monitoring
Add the organization to the SolarWinds Platform database as an external node.
Each Meraki Organization monitored with NPM uses a node license.
  1. Log in to the SolarWinds Platform Web Console as an administrator.
  2. Click Settings > Manage Nodes, and click Add a Node.
  3. In Polling Method, select Orchestrators: API.
  4. Under Orchestrators, select Meraki Devices.
    The Polling Hostname or IP Address is disabled and api.meraki.com is used as the default host name for Meraki networks. If your organization has a different domain suffix, see Change the default hostname for your Cisco Meraki organization.
  5. Provide the API Key you generated in the Cisco Meraki Dashboard.
  6. If you have multiple organizations registered, click Get Organization List, and select the organization. If you have one registered organization, it is selected by default.
    Polling Meraki Organizations uses the global HTTP proxy settings. To change the defaults, click the Configure your HTTP proxy link.
    By default both wireless information and SD-WAN metrics are polled. If you do not want to poll one of the items, clear the appropriate box. See Cisco Meraki Secure SD-WAN.
  7. Review and adjust the device properties.
    1. Review your API key, organization, and proxy settings.
    2. To edit how often the node status, or monitored statistics are updated, change the values in the Polling area.
      For critical nodes, you may need to poll status information or collect statistics more frequently than the default polling intervals.
    3. Enter values for custom properties for the node.
      The Custom Properties area is empty if you have not defined any custom properties for the monitored nodes. See "Add custom properties to nodes" in the SolarWinds Platform Product Guide.
    4. To adjust when the status of the node changes to Warning or Critical, edit alerting thresholds for the metric. Select the Override box and set thresholds for the node.
  8. Click OK, Add Node.
The Meraki Organization is now monitored as a wireless controller node. After the first poll, you can see the data from the device in the SolarWinds Platform Web Console.
On the Manage Nodes view, click the added node to see the node details in the Wireless Controller view, or drill down into thin access points listed on the view.
Monitor Meraki Organizations
Click My Dashboards > Network > Wireless to see monitoredMeraki Organizations in the Wireless Overview and to view monitored controllers, access points, and clients.
Access Points tab
To find access points on a controller, expand Filters > Controllers, and select the controller to find access points for.
Clients tab
Click a wireless access point to see details of the access point, such as the controller details, thin access point details, active wireless clients, and wireless clients connected in the past.
Click the controller name to see the wireless controller details, such as node details or list of thin access points.
Edit Meraki Organizations
Edit polling details, custom properties or alerting thresholds in the same way as other nodes in NPM.
When you add a Meraki Organization to NPM, you can no longer change the polling method from the UI.
