HPE Aruba Networking switches
Track performance, availability, and configuration metrics for your Aruba switches using SNMP.
Gain enhanced visibility into Aruba switches. Monitor port utilization, CPU, memory, and interface metrics to ensure proactive troubleshooting.
Monitor hardware health. Track hardware health metrics, including temperature, fan status, and power supply monitoring.
Gain insight into topology. View data for STP, MAC address tables, and VLANs where supported.
To get accurate Aruba specific information, add the device for monitoring as a node using SNMP as the polling method. Review the node details view or view your Aruba switches on topology maps.
Supported devices
Switch monitoring is designed to support switch models with similar MIB implementations and compatible firmware versions. Switch monitoring was validated on the following devices using multiple firmware versions, primarily on firmware v10.07.0005.
Aruba 6300M
Aruba 2930F
Aruba 2930M
Aruba 3810M Stack
This is not a comprehensive list of all supported Aruba switches. If your model is not on the list, ensure that its MIB structure and configuration is similar to a listed versions.
Limitations
The following metrics are not available because Aruba switches do not expose the required SNMP OIDs:
VLAN Details: Metrics for VLAN membership and configuration are not exposed.
Link Aggregation: Aruba switches lack OIDs for monitoring LAG status and load distribution.
Quality of Service (QoS): Traffic prioritization and buffer management metrics are not provided.
Routing Metrics: Layer 3 routing information, such as OSPF or BGP, is not exposed via SNMP.
Supported metrics
Performance metrics
Port Utilization - bandwidth usage, transmitted/received packets, and errors.
CPU utilization
Memory utilization - total, used, and free memory
Interface errors and discards - CRC errors, frame errors, and packet drops.
Availability and reliability metrics
Switch uptime - uptime and reboot events
Environment monitoring - temperature, fan speed, and power supply metrics
Network topology and configuration
Spanning Tree Protocol (STP) - port roles, topology changes, and root bridge details
Layer 2 and 3 metrics
MAC address table utilization - MAC address entries and usage
Hardware health metrics
Hardware health monitors temperature, fan, and power health using standard MIBs.
