ExtremeCloud IQ
Add Extreme Networks ExtremeCloud IQ orchestrator nodes for monitoring wireless access points, wireless interfaces, and clients via API polling.
Monitored metrics
| Monitored entity | Metrics |
| Controller |
| Access Point |
| Interface |
| Client |
Requirements
- ExtremeCloud IQ account with at least read-only permissions.
Limitations
Not all wireless utilization data is collected (only InBytes and OutBytes for wireless interfaces are collected and processed).
Rogue AP data is not available from the vendor's API.
Use the default polling frequency (10 minutes)
The status poller uses API authorization requests to determine whether a node is responsive. API calls can take more time, and as a result, response time thresholds are exceeded. The nodes might appear to be exceeding the warning or critical status without showing any signs of connectivity problems (0% packet loss). Consider adjusting the response time thresholds for the nodes to better represent the average response times.
Poll Now is not supported.
Discovery is not supported. Use the Add Node wizard instead.
Request frequency and limits
Extreme Networks devices support up to 7500 API requests for each customer. See Default Quota in Extreme Networks documentation.
API calls used for polling wireless access points
| API request | Purpose | |
| 1 | \auth\apitoken\info | Status polling |
| 2 | \login | Authentication with username & password in order to obtain a Bearer Token. |
| 3 | \devices\<ID>\interfaces\wifi | Statistics Collection poller - gets the utilization of wireless interfaces. |
| 4 | \devices\radio-information?deviceIds=<ID> | Statistics Collection poller - gets information on AP data. Uses one request per one access point |
| 5 | \clients\active | Statistics Collection poller - gets client data. |
| 6 | \devices\radio-information | Statistics Collection poller - gets data on wireless interfaces. |
Before you begin
Prepare the Extreme Networks ExtremeCloud IQ credentials - username and password for the orchestrator node.
Add your wireless infrastructure for monitoring
Log in to the SolarWinds Platform Web Console as an administrator.
Click Settings > Manage Nodes and click Add a Node.
In Polling Method, select Orchestrators: API.
The Polling Hostname or IP Address is disabled and
api.extremecloudiq.comis used as the default host name. -
Select ExtremeCloud IQ Devices and provide the Username and Password for the orchestrator node.
The polling uses the global HTTP proxy settings. To change the defaults, click the Configure your HTTP proxy link.
Review and adjust the device properties.
Review the user details and proxy settings.
To edit how often the node status, or monitored statistics are updated, change the values in the Polling area.
Enter values for custom properties for the node.
The Custom Properties area is empty if you have not defined any custom properties for the monitored nodes. See "Add custom properties to nodes" in the SolarWinds Platform Product Guide.
To adjust when the status of the node changes to Warning or Critical, edit alerting thresholds for the metric. Select the Override box and set thresholds for the node.
The status poller uses API calls with authentication. This can take longer than if the default ICMP polling was used. Consider adjusting the response time thresholds for the nodes to better represent the average response times.
Click OK, Add Node.
The ExtremeCloud IQ device is now added as a node. After the first poll, you can see the data from the device in the SolarWinds Platform Web Console.
On the Manage Nodes view, click the added node to see the node details in the Wireless Controller view, or drill down into thin access points listed on the view. Check Node Details to verify that the Machine Type of the new device is ExtremeCloud IQ Cloud Orchestrator.
