How to upload Cisco IOS config from TFTP to device
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
This example demonstrates how to upload an IOS to a device using the Device.CLI.Send commands activity.
- Open KCT NG.
- In the Activities panel, click Add.
- Click the Activity tab.
- Select Type
Device.CLI.Send commands - Enter a name and description, for example "Upload Cisco IOS config".
- Select Type
- Click the Options tab.
- Select List of commands to be entered on device and enter the following code:
copy tftp running
192.168.1.200
%ctGroupName\%ctDeviceName-Config.txt (Filename to store config to on server)
%ctCR (Required to start device TFTP)%ctGroupName\%ctDeviceName-Config.txt: the filename to store config to on server.Note the use of a backward slash in the filename to specify a subfolder within the TFTP Upload folder.
%ctGroupName: device group name%ctDeviceName: device name
%ctCR: carriage return. Required to start the device TFTP. The%ctCRvariable to send a<CR>to the device to activate the TFTP session.
- Select
Enter commands in enable mode. - Select
Save device output to file. Specify the log file name. - Select
Overwrite existing capture file. - Select
Answer yes to any confirmation prompts. - Select
Stop on error.
The Device.TFTP.Upload Config activity could also be used to upload an IOS to a device.
The TFTP service can only run on one application at a time. If you have TFTP enabled on KCT (version 3.12.7 or earlier), you will need to stop the service before enabling it in KCT NG.
