Documentation forKiwi CatTools NG
Unsupported activities for a device
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
Device types are updated all the time. For an up to date list of the devices types currently available in KCT NG and the activities supported for each of the device types, please see the device matrix.
If there is a listing to support your device, but the activity you require is not currently supported by the device type then please contact us using the Technical Support form, providing us with as much detail as you can and if possible a PuTTY capture of the relevant command(s).
