Kiwi CatTools API: Device class
The Device class is used encapsulates a Kiwi CatTools device.
Properties
| AAAUsername / AAAPassword |
The username and password to use if your device requires a username/password login. |
AAAUserPrompt / AAAPassword Prompt |
The prompt request for the username and/or password of your device. |
| ActivitySpecific1 / ActivitySpecific2 |
Not used |
| Address1 / Address2 / Address3 |
The location of the device. |
| AlertEmail |
User to receive notifications by e-mail for any triggered alerts from this device. |
| AssetTag |
Asset tag information. |
| ConnectionMethod |
The method to use when connecting to this device.
| ConnectVia |
The name of the device to connect via. |
| ConnectViaID |
The ID of the device to connect via.
| ConsolePassword |
The console (com port connection) password. |
| ConsolePrompt |
What does the console password request look like from your device. |
| ContactName / ContactEmail / ContactPhone / ContactOther |
Contact information for the person responsible for a device. |
| EnablePassword |
The password to get into enable mode. |
| EnablePrompt |
What does the enable password request look like from your device. |
| EnableUsesAAA |
Does entering enable mode require username/password validation? |
| FileName |
The base file name for the device. |
| Group |
The name of the Group the device belongs to. For example: |
| GroupID |
The id corresponding to the Group field. -1 indicates a new Group is to be created. |
| HostAddress |
The IP address or host address for this device. |
| ID |
The id that identifies this device in the database. |
| Identification |
Identification info for this device. |
| LoginUsesAAA |
Does connecting to the device require username/password validation? |
| Model |
A value describing the model of the device. |
| Name |
A unique name that describes this device. |
| Port |
The port to use when connecting to this device. |
| PrivilageLevel |
Sets the enable mode privilege level. |
| RequireVTYLogin |
Does connecting to the device require password only validation? |
| SerialNumber |
The serial number for the device. |
| SerialOther |
Additional serial number information. |
| SNMPRead |
SNMP Read community name. |
| SNMPWrite |
SNMP Write community name. |
| SSHPassword |
The SSH password required for SSH connections to this device. |
| SSHUsername |
The SSH username required for SSH connections to this device. |
| TypeID |
The id of the device-type eg 10 |
| TypeOfDevice |
The name of the device-type. For example: |
| VTYPassword |
The password to use if your device verifies using a password only to log in. |
| VTYPrompt |
What does a password request look like from your device. |
Example code: Add, edit, or delete entries in a database
The following sample Visual Basic code showing you how to use the Device object of the CatTools API to add, edit or delete an entry in the database.
Add an entry to a database
Dim DB As CatToolsAPI.Database
Dim Device As CatToolsAPI.Device
Set DB = New CatToolsAPI.Database
If DB.OpenConnection Then
Set Device = DB.Devices.AddNew("Cisco.Router.General")
If Not Device Is Nothing Then
Device.Name = "My Device 01"
Device.HostAddress = "192.168.1.1"
Device.Group = "My Test Group"
Device.RequireVTYLogin = True
Device.VTYPass = "My Password"
Device.ConnectionMethod = "Telnet"
If DB.Devices.SaveDevice(Device) Then
Debug.Print Device.Name & " saved to the database OK."
Else
Debug.Print "Adding " & Device.Name & " failed: " & DB.ErrDescription
End If
Else
Debug.Print "Creation of a new device failed: " & DB.ErrDescription
End If
Else
Debug.Print "DB connection failed: " & DB.ErrDescription
End If
Set Device = Nothing
Set DB = Nothing
Edit an entry in a database
Dim Devices As CatToolsAPI.Devices
Set Devices = DB.Devices
Set Device = Devices.GetByName("My Device 01")
Debug.Print Device.Name & " Loaded OK"
Device.AAAPassword = "My New Password "
If Devices.SaveDevice(Device) Then
Debug.Print Device.Name & " saved OK"
Else
Debug.Print Device.Name & " NOT saved: " & DB.ErrDescription
End If
Else
Debug.Print "Device not found"
End If
Else
End If
Set Devices = Nothing
Set DB = Nothing
Delete an entry from a database
If DB.Devices.DeleteByName("My Device 01") Then
Debug.Print "Deleted OK"
Else
Debug.Print "Delete failed: " & DB.ErrDescription
End If
Else
End If
Set DB = Nothing
