Scripting Options
SolarWinds does not recommend usage of Trivial File Transfer Protocol (TFTP) in KCT due to potential security vulnerabilities. If TFTP must be used, it is highly recommended to take precautions and limit its exposure
This pane allows you to specify VBscripts that are run before and/or after a TFTP session. To set scripting options:
- Go to Options > Setup.
- Select the TFTP Server tab.
- Select the Scripting Options.
Use the tick boxes to determine whether a script is run and enter the full path to the script in the appropriate text box.
| Timing Issues | It's important to note that you only have 1 second to get everything done in the pre-session external script and return a value otherwise the TFTP session times out, and retries. |
| Scripting Information |
Your script must start with Function Main (session) where session is the TFTP session being passed in.
For security reasons if the script can not be loaded or if the script fails then the TFTP session is aborted. |
Scripting information session properties
You can access the following properties of the session:
| Session.CreatTime |
The time the session was started by the host. Represented as the number of seconds from midnight 1/1/1970 UTC. |
| Session.FileName | Name of the file to be written. |
| Session.FileSize | Size of the file on the server for a 'Get' operation. This is zero for a 'Put' operation. |
| Session.Host | IP address of the remote client represented as a long. The address is converted from an 8 digit hex value. |
| Session.Hosts |
IP address of the remote client represented as a string. For example: |
| Session.Port | TFTP Port on the remote client. |
| Session.TransferSize |
The number of bytes transferred so far. In the pre-session script, this is zero. In the post-session script, this is the whole file size. |
| Session.Type |
Example Scripts
The script below checks the host address of the remote client issuing a Put. If it matches a certain address then the filename is changed.
Rename of the file based on host address
Function Main(session) Main= False With session If .HostS = "192.168.1.60" Then .FileName = "NewFileName.txt" End If End With Main= True End Function
Reject a file based on the time of day
Dim CreateHour
Main= False
With session
'convert the create time from the unix format to the current time
CreateHour = DateAdd("s", session.CreateTime, DateSerial(1970, 1, 1))
'convert to 24 hour format
CreateHour = FormatDateTime(CreateHour, vbShortTime)
'seperate out the hour value only
CreateHour = DatePart("h", currentTime)
Select Case CreateHour
'reject files created two hours either side of midnight
Case 1,22,23,24
'accept files created at any other time
Main=False
Case Else
Main=True
End Select
End With
End Function
There is a known bug that occurs if a script is triggered in the pre-session event that renames the filename, such as .FileName = "NewTestFileName.txt". The file is put into the TFTP folder with the filename correctly changed to NewTestFileName.txt but the existing Test.txt file in the TFTP folder is deleted.
