Documentation forKiwi CatTools NG
Kiwi CatTools NG Info log pane
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
The Info log pane displays a grid of all messages displayed by KCT NG while it is running, in the order that they occur. The display may be filtered by using the View filter.
The messages are also logged to infolog.txt in the main CatTools folder.
Option Description
View Filter Drop-Down
This allows you to change the filter options on the Info Log display which controls which level of messages are displayed.
There are four filters available:
  1. Show Error events only.
  2. Show Warning events and above.
  3. Show Info events and above. This is the default setting.
  4. Show Debug events and above
Clear Info log
Clears the Info Log display.
