Meta Variables
Several Activities allow you to enter a list of commands which are issued to your selected devices. Device.CLI.Send commands, Device.CLI.Modify Config and Device.Update.Banner are examples of these activities.
Within the commands you send, you can include a number of CatTools Meta Data variables that are translated when the activity is run.
For example, in the Device.Update.Banner activity you could set the following text and apply it to all your devices:
Hello, I am %ctDeviceName. Contact %ctContactName on %ctContactPhone to gain access to me.
Available Meta Variables
| Variable | Value |
%ctDeviceName
The device name |
%ctGroupName
The device group name |
%ctHostName
The device host address |
%ctModel
The device model field |
%ctAddress1
The device Address1 field |
%ctAddress2
The device Address2 field |
%ctAddress3
The device Address3 field |
%ctContactName
The device Contact name field |
%ctContactPhone
The device Contact phone field |
%ctContactEmail
The device Contact email field |
%ctTimeHHMM |
Current time in HHMM format |
%ctDateISO
Current date in YYYYMMDD format |
%ctBaseFile
Device base file name |
%ctAppPath
File system path of the CatTools executable including a trailing " |
%ctCR
Carriage return |
%ctLF
Line feed |
%ctTAB
Tab |
%ctCTRL-Z
Control key & Z. Normally used to exit config mode. |
The variable names are case sensitive and must be entered as shown.
