Kiwi CatTools NG View menu
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
The View menu allows you to review KCT NG data files using the notepad editor.
| Menu option | Description |
| Reports folder |
View the Reports folder using Windows Explorer. The reports from scheduled activities are stored in the You can view the reports with MS-Excel, Log Viewer or use the internal viewer in KCT NG from the Reports tab. |
| Captured Data folder |
View captured data using Windows Explorer. The data captured from scheduled activities is stored in the You can view the reports with MS-Excel, Log Viewer or use the internal viewer in KCT NG from the Reports tab. |
| Configs folder |
View the configs folder using Windows Explorer. The device configurations from the Device.Backup.Running Config configuration activity are stored in the You can view the configs with Notepad or Wordpad etc. |
| Email log |
View KCT NG email activity log file using Notepad. |
| Activity log |
View KCT NG activity summary log file using Notepad. |
| Info log |
View KCT NG info log file using Notepad. |
