Kiwi CatTools NG pane interface
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
KCT NG includes a docking panes interface. The panes interface is a customizable, tabbed layout allowing users to hide and show the panes that matter to them and to have two or more panes viewable at the same time.
Reset the pane to default
To reset the panes back to the KCT NG default, click on the Interface > Panes > Restore to default layout.
See Interface for further details.
Right-Click short menu
The functions of the buttons at the bottom of the tabs can also be accessed via the shortcut menu by selecting a row from within a pane and clicking the right mouse button.
The shortcut menu also includes other items which are specific to the pane in which you are currently in. For example, on the Activities pane, there is an item called "Columns" which contains sub items to show and hide data columns relating to activities; Show and Hide the grouping box which allows you to group your activities by data columns, and restore the pane back to its default layout.
You can maximize the current pane by right clicking and selecting the Maximize Pane menu option. To return a maximized pane to its normal size right click and select restore panes.
Chapter Topics
This chapter covers the following topics:
