Kiwi CatTools NG Options menu
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
The Options menu allows you to change the setup options in Kiwi CatTools NG.
| Menu option | Description |
| Setup |
This menu item displays a form that enables you to set the general properties of KCT NG.
| Device Wizard |
The Device Wizard helps guide you through the addition of new devices to the KCT NG database. Alternatively you can add new devices from the Devices pane. |
| Activities Wizard |
The Activities Wizard helps guide you through the addition of new activities to the KCT NG database. Alternatively you can add new activities from the Activities pane. |
