Documentation forKiwi CatTools NG
Reporting problems
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
When reporting a problem with KCT NG to the SolarWinds technical support team, ensure you provide as many details as possible. Doing so allows our support team to better review and troubleshoot your inquiry.
Best practices
  • Provide the complete wording of the error you are receiving. The error message should be present in infolog.txt that describes the error.
  • Provide the type of device with the problem. KCT NG supports a number of different devices that can exhibit very different problem behaviors.
  • Include the approximate time the problem occurred.
  • Do not send raw screen shots of messages or setup issues, unless there is no other way of getting the information across. Mail servers often block this data. Use the KCT NG facilities from the File menu to provide textual information.
  • Send the complete infolog.txt file as a zipped attachment. Trying to copy and paste entries from the infolog into an email can produce poorly formatted emails.
