Kiwi CatTools NG Upgrade Guide
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
Supports: Kiwi CatTools NG 2026.2.1 and earlier
Preflight checklist
Complete the checklist below to prepare for upgrading Kiwi CatTools NG.
Review release notes | Review the Kiwi CatTools NG release notes. |
Review system requirements | Verify that the server meets the hardware and software requirements |
Run all Windows updates | Before the upgrade, check for and run all Microsoft Windows Updates on the server. As you upgrade, if a Windows update runs, your system might reboot. |
Check for and disable anti-virus software |
Determine if any anti-virus software is installed on the server where you plan to install Kiwi CatTools. |
Upgrade Kiwi CatTools NG
When you upgrade to the latest version of Kiwi CatTools NG, your devices, scheduled actions, and other configuration settings are preserved. If you previously entered a license key, the key is automatically applied to the new version.
If you upgrade from KCT NG 3.12.2, the Kiwi CatTools NG database will automatically update and your data will be re-encrypted using AES (Advanced Encryption Standard). If the database updates, the changes cannot be reverted.
While a typical upgrade takes approximately one minute to perform, this does not include the time required to backup your system or perform upgrade validation testing.
When updating Kiwi CatTools NG you must choose to install the Kiwi CatTools NG update as an application or as a service:
- Installing Kiwi CatTools NG as an application is recommended if you need to run one-off or attended activities or for infrequent or part-time users who are running Kiwi CatTools NG on their own personal computers.
Installing Kiwi CatTools NG as a service installation is recommended for Enterprise customers, as well as anyone running unattended activities, who need to make use of around-the-clock scheduling, or who are dedicating a machine specifically for Kiwi CatTools NG to run on.
For more information on the differences between application mode and service mode, see Installing Kiwi CatTools NG as an application or a service.
Backup your existing installation |
Make a full backup of your existing installation, including the database. See Backup current database. |
Uninstall the current version |
Download the installation file |
Run the installation file |
Complete the Kiwi CatTools NG Setup wizard |
The installer displays status messages as Kiwi CatTools NG is installed. |
Close the Wizard | Click Finish to close the Kiwi CatTools NG Setup wizard and open Kiwi CatTools NG Manager. |
Start Kiwi CatTools NG in application mode | Start the new update in application mode the first time, then change to service mode, if required. |
