Documentation forKiwi CatTools NG
Unsupported devices or device activities in Kiwi CatTools NG
This topic applies to KCT NG 2026.2 and later. If you are on KCT 3.12.7 or earlier, see legacy topic.
If your device is not included on the list of CatTools supported device types, and is not covered by one of the CatTools generic scripts, don't worry. Support for additional device types are being added to Kiwi CatTools all the time.
For an up to date list of the devices types currently available in CatTools and the activities supported for each of the device types, see the device matrix.
Get support for devices added to KCT NG
Requesting support for your device
If you would like us to consider adding your device then please submit a feature request to let us know your requirements. When considering what devices to add we look at the following factors:
  • If SolarWinds can get network access to a device.
    This is by far the fastest way to add a new device. If you can send support a user name and password for your device, and support can log into it from their labs, then adding support for it is so much easier.
  • How many requests SolarWinds has for support of that device type.
    Even with limited resources and time, SolarWinds strives to help as many people as possible. A device with a large number of unique requests helps SolarWinds identify those devices that the majority of KCT NG users desire support for.
  • How much information SolarWinds has on the device.
    If the support team cannot gain network access to a device, the next best thing is to see how the device works by examining logs captured from it. It is recommend you capture logs using a tool such as PuTTY.
The more information about the device you can provide SolarWinds support with, the better.
Sample device responses to report when requesting device support
The following are examples of the sort of responses we need to see from your device. If the action is not obvious, such as a Ctrl+Z keystroke, then this should be explained:
  • A successful login
  • A failed login. Showing responses to bad user name and password entries
  • An invalid command being entered
  • An incomplete command being entered
  • Successfully entering and exiting enable/privileged mode
  • Successfully entering and exiting configuration mode
  • How to save changes to the configuration, such as write memory or copy running startup
  • How to display the configuration (both running and startup)
  • A show version type command
  • The necessary commands to show Port / MAC / ARP information
  • Results of a Ping command. Success, failure, and unreachable.
  • Commands to enable and disable paging
  • A --More-- prompt (or equivalent paging prompt)
  • A Yes / No prompt (or equivalent confirmation prompt)
Requesting support for a device activity
If there is a listing to support your device, but the activity you require is not currently supported by the device type, please submit a feature request, providing us with as much detail as you can and, if possible, include a PuTTY capture of the relevant command(s).
