Register an Azure SQL Managed Instance
Complete the following tasks to register a single Azure SQL Managed Instance (ASMI) for DPA to monitor.
You can also use mass registration to registrations to register multiple database instances, or you can register database instances using scripts that call the DPA API.
For DPA to collect metrics from a monitored SQL Server instance, Azure SQL instance, or ASMI, the SQL option NUMERIC_ROUNDABOUT must be set to OFF.
Differences when registering an ASMI
Registering an ASMI is slightly different than registering other types of monitored database instances:
You cannot use the wizard to create the DPA monitoring user. Do one of the following:
Create the monitoring user manually.
If you don't want to create, manage, and update user credentials, you can use a Microsoft Entra service principal (previously Azure service principle). See the prerequisites below.
If the DPA repository is an Oracle database, DPA stores performance data for monitored ASMIs in the default tablespace of the repository user. You cannot change the default tablespace in the Register Instance Wizard. If you need to change the default tablespace, register the instance using mass registration.
If you are not using a Microsoft Entra service principal as the DPA monitoring user, you must create a user account to serve as the DPA monitoring user. DPA uses this account to register and monitor the instance.
DPA ignores data on the monitored database instance from the monitoring user. Make sure the monitoring user will not cause load on the monitored instance.
The monitoring user account must have the SYSADMIN role during registration. After you have registered the ASMI, you can (optionally) remove the SYSADMIN role from the DPA monitoring user. If you remove the SYSADMIN role, DPA functionality is limited. For example, the SQL Server Log Has Many Virtual Logs alert does not work.
Copy the following script to a file:
--Create DPA login CREATE LOGIN username WITH PASSWORD=N'password', DEFAULT_DATABASE=[master], DEFAULT_LANGUAGE=[us_english], CHECK_EXPIRATION=OFF, CHECK_POLICY=OFF GO --Give SYSADMIN rights to the DPA user EXEC sys.sp_addsrvrolemember @loginame = N'username', @rolename = N'sysadmin' GO -
Edit the script to update the user name and password values.
Connect to the SQL Server database instance and run the script. To ensure that the connected user has all the privileges needed to create the monitoring user, SolarWinds recommends connecting as
sysadminto run the script.
Prepare to authenticate with a Microsoft Entra ID password
If you plan to use a Microsoft Entra ID (formerly Azure AD) password to authenticate the DPA monitoring user, complete the following steps:
Add the Active Directory admin to the Logical Server where the monitored database is located. See Configure and manage Microsoft Entra authentication with Azure SQL from Microsoft for more information.
Connect to the Azure database with an Active Directory account and execute the following script:
CREATE USER [activeDirectoryUser@*.onmicrosoft.com] FROM EXTERNAL PROVIDER; ALTER ROLE db_owner ADD member [activeDirectoryUser@*.onmicrosoft.com];
Prepare to authenticate with a service principal
If you plan to use a service principal to authenticate the DPA monitoring user, complete the following steps:
In the Azure portal (https://portal.azure.com) under Azure services, click App registrations. Then register an app.
You can use an existing app if you already have one.
Use the SQL Server Management Studio (SSMS) to connect to the ASMI database instance at the server level, and run the following SQL statements to create a user and give it the
db_ownerrole:CREATE USER appName FROM EXTERNAL PROVIDER; ALTER ROLE db_owner ADD member appName; -
Run the following SQL statements to grant the
sysadminrole.CREATE LOGIN appName FROM EXTERNAL PROVIDER WITH DEFAULT_DATABASE=master, DEFAULT_LANGUAGE=us_english ALTER SERVER ROLE sysadmin ADD MEMBER appName
Complete the Register Instance Wizard
On the DPA home page, click Register DB Instance for Monitoring.
Under Microsoft Azure, select Azure SQL Managed Instance. Then click Next.
On the Enter Monitored Database Instance Connection Information panel, enter the server name or IP address of the ASMI and the port number.
Under Authentication method, select the type of authentication to use for the monitoring user account:
- SQL User
- Microsoft Entra Password (formerly Azure Active Directory password)
- Microsoft Entra Service Principal (formerly Azure service principal)
Do not specify the authentication method in the Connection Properties field.
Specify the monitoring user credentials, and then click Next:
To specify an account, enter the user name and password for the monitoring user account that you created previously.
To specify a service principal:
In the Username field, enter the service principal application ID.
You must enter the application ID, not the display name or object ID.
In the Password field, enter the value of the service principal secret.
Specify the following Instance options.
The instance name and group membership can be changed after registration.
Enter the name that DPA will display to identify this database instance.
The Display name field defaults to the ASMI name retrieved from the instance.
(Optional) If you have manually created instance groups, you can assign this database instance to one of the groups.
If no manual groups exist, this option is not shown.
(Optional) If you have existing alert groups, you can assign this database instance to one or more groups.
If no alert groups exist, or the existing groups do not match this instance's database type, this option is not shown.
Click Next.
- Review the information on the Summary page. Click Back if you need to make changes. When the information is correct, click Register.
