Customize a DPAIM view and apply limitations
View limitations restrict the information available for a specific view.
- In the SolarWinds Platform Web Console, click My Dashboards > Databases > Databases Summary.
- Click Customize Page in the upper right.
- To change the title of the page, edit the Name field, and then click Update.
- To add a subview that can be accessed from tabs on the left:
- Select the Enable left navigation checkbox.
- Click Add Tab.
- Enter a name in the Tab Name field.
- Click Browse next to Tab Icon, and select an icon for this tab.
- Click Update.
- You can add more tabs, or continue.
- To change the width of a column, enter the width in pixels in the Width field beneath the column.
- To add a column, click Add New Column.
- To add a resource, repeat the following steps for each resource:
- Click + next to the column in which you want to add a resource.
- Select the resources to add, and click Add Selected Resources.
- Use the icons next to each column to delete, clone, or move the selected resources.
- To cycle the web console view through its database instance monitoring resources for continually updated and shared viewing, select Enable NOC view mode.
- Click Preview to view your configuration in a new window.
- Click Done.
Restrict access by applying view limitations
View limitations restrict the information available in a view for specific objects or database instances.
- Log in to the SolarWinds Platform Web Console as an administrator.
- Click My Dashboards > Databases > Databases Summary.
- Under View Limitations, click Edit.
- Scroll to the bottom of the list, and select a limitation type for the view. Integrating Database Performance Analyzer and an SolarWinds Platform product grants you the following additional view limitation types:
- Single Database Instance
- Group of Database Instances
- Database Instance Name Pattern
- Click Continue.
- Select a single database instance, group of database instances, or enter a name pattern.
- Click Submit.
