Documentation forDatabase Performance Analyzer
DPA troubleshooting tips
See the following sections:
Logs
DPA logs information about each monitored database instance. Use this information to help you determine why a database instance is not being monitored, or if data are missing.
Access log data through the DPA log viewer
Use the DPA Log Viewer to view log information for a specific database instance, or for all database instances and the DPA repository.
  1. Open the Log Viewer:
    • To display log messages for a specific database instance:
      From the DPA home page, click Action > Log next to the database instance.
    • To display messages for all monitored database instances and the DPA repository:
      From the DPA menu in the upper-right corner, click Options. Then, under Support > Utilities, click Log Viewer.
  2. Use any of the following options to locate information:
    • Use filters to help you find specific information. To change the filters, click Advanced and select the filter criteria. For example, you can filter by date range, a text string, or message level.
    • For any message above Info, click Details to view additional information from the log.
    • Click Log Files for Support to create a compressed file you can send to SolarWinds Support.
Open log files in a text editor
Log files are stored in the DPA-install-dir/iwc/tomcat/logs/ directory on the DPA server.
Download log files to a DPA client
You can download some or all DPA log files from the Management Options page.
  1. Log in to DPA as a user with administrative privileges.
  2. From the DPA menu in the upper-right corner, click Options.
  3. Under Support > Downloads, click one of the following options:
    • To download all log files, click All Log Files (Zipped).
    • To download the idc.log file, click Data Collection Log File.
    • To download the iwc.log file, click Web Client Log File.
    • To download the wizard.log file, click Wizard Log File.
Information contained in each log file
DPA provides the following log files.
File name Contents
api.log Messages associated with calls to the API.
appevents.log Messages associated with Oracle PDB and CDB movements.
auth.log Messages associated with logins or LDAP / AD integration issues.
catalina.date.log Messages associated with Tomcat and loading other log files.
central.log
Messages associated with DPA Central.
cloud.log Messages associated with license issues for the AWS metering service, including errors received from the Amazon Marketplace Metering Service.
commons-daemon.date.log Messages associated with the Tomcat commons-daemon.jar file.
deadlock.log
Errors that occurred while collecting data about deadlocks.
diagnosticsSystem.log
Diagnostic information about:
  • The Java virtual machine (JVM), such as heap and non-heap memory and thread information.
  • The OS, such as memory metrics and the number of processors.
  • DPA, such as the start time, up time, and number of monitored instances.
diagnosticsTiming.log Diagnostic information about the top poll times and the top cleaner times.
diagnosticsStatsTiming.log Diagnostic information about the stats poll timings for each monitored instance.
emailReport.log A record of reports that were sent by email on a schedule.
errors.log
Error messages that are also logged to iwc.log or idc.log. This file includes only error messages (no warnings or informational messages), and the messages are kept longer than those in iwc.log and idc.log.
gen3.log
Messages associated with license activations and deactivations, and messages about synchronization issues for offline servers that have the LICENSE_AUTO_UPDATE property set to true.
idc.log
Messages associated with DPA data connections, including connections to the monitored database instances and connections to the repository. This log also records changes to advanced options.
iwc.log Messages associated with DPA web-related items, including display issues, reports, and alerts.
license.log Messages associated with license activations and deactivations.
massReg.log Messages associated with mass registration of monitored instances.
orion.log
Messages associated with the DPA Integration Module (DPAIM).
Messages about DPA integration that were generated by the SolarWinds Platform can be found on the SolarWinds Platform server. The default location is C:\ProgramData\SolarWinds\Logs\DPA.
rest.log Messages associated with the DPA REST API, including information about requests and responses.
stderr.log Errors generated by the web apps.
stdout.log System.out messages generated by the web apps.
swagger.log Messages associated with the Swagger interface, which is used to document the DPA REST API.
swip.log
Messages associated with the SolarWinds Improvement Program (SWIP).
swis.log Messages associated with the DPA Integration Module (DPAIM).
uams.log Messages associated with the UAMS client.
wizard.log Messages associated with the repository creation wizards.
Change the default ports
If the default ports of 8124 and 8127 are in use, change the ports that DPA uses.
SolarWinds recommends you do not change the default ports unless there is a conflict.
  1. Open the following file in a text editor:
    DPA-install-dir/iwc/tomcat/conf/server.xml
  2. Update one or both of the following lines with new port numbers:
    <Server port="8127" shutdown="SHUTDOWN">
    				<Connector port="8124"/>
    You cannot use the same port for both of the lines.
  3. Save the file and restart DPA.
When monitoring PostgreSQL databases with queries that return a large amount of data, DPA runs out of memory
The JDBC fetch size defines how many records are returned in one network call. If all data cannot be returned in one call because of the fetch size, multiple calls are issued.
By default, PostgreSQL does not set a fetch size, and attempts to return all data in one call. When a large amount of data needs to be sent to DPA, DPA can run out of memory. If this occurs, the idc.log file includes errors such as:
ERROR (2023-08-29T18:55:17,717-0400) [repositoryManager-thread-12] {name=MS-DB-PROD} PostgreSQLTextPollService:227 - Error getting data from pg_stat_statements.
org.springframework.dao.DataAccessResourceFailureException: PreparedStatementCallback; SQL [SELECT query FROM pg_stat_statements GROUP BY query ORDER BY SUM(total_time) DESC LIMIT ?]; Ran out of memory retrieving query results.; nested exception is org.postgresql.util.PSQLException: Ran out of memory retrieving query results.
Resolution: In new installations of DPA 2024.2 and later, the following property in the system.properties file sets a fetch size value for data that DPA retrieves:
com.confio.idc.database.service.statspoll.postgres.fetchsize=300
The default is 300, but this value is configurable. If you see errors such as the ones above:
  • If the system.properties file on your DPA server does not include this property (for example, upgrading customers), add it.
  • If the system.properties file includes the property but you still see the errors, decrease the value.
To add or change the property value:
  1. Open the system.properties file in a text editor. This file is located in the following directory:
    DPA-install-dir/iwc/tomcat/ignite_config/idc
  2. Add the following property, or decrease its value:
  3. Save the file.
  4. Restart DPA for the changes to take effect.
Connection attempts that use the HTTP connector port fail with a message that the DPA site can't be reached
For security reasons, HTTPS connections are required by DPA 2023.2 and later versions. Connection attempts that use the HTTP connector port are not accepted. To ensure that DPA is available to users who previously connected over HTTP, you can update the server.xml file to redirect traffic to the HTTP connector port (8123 by default) to the HTTPS/SSL connector port (8124 by default).
If the redirect is not added and users attempt to connect over HTTP, they will receive a message that the site can't be reached.
Resolution:
    DPA-install-dir\iwc\tomcat\conf\server.xml
  2. Locate the Connector property below <!--HTTPS/SSL connector>, and note the port value. (By default, this is 8124.)
  3. Locate the Connector property below <!--HTTP connector>. Within the Connector property, add the following, where hpptsPortNumber is the port value noted in the previous step:
    redirectPort="hpptsPortNumber"
    For example:
    redirectPort="8124"
  4. If you make these changes after the upgrade, restart DPA for the changes to take effect.
Access to a database instance
If DPA cannot access the server that hosts a database instance you want to monitor, make sure the port used for DPA connections is accessible. The port cannot be:
  • Blocked by a firewall
  • In use by another process
To determine if the port can be accessed, see Use PowerShell to test that a port is open on a server.
The port used for DPA connections is specified when you register the instance. If the instance is already registered, you can use the update wizard to view or update connection information.
Issues after the Oracle PDB that stores the repository is moved
If the DPA repository is created on an Oracle pluggable database (PDB), you might experience the following issues after the PDB is moved to a different container database (CDB).
DPA returns a connection error
The PBD moved to a CDB on a different server, and the connection string is incorrect.
Resolution: Update the connection string in the repo.properties file in the following location:
DPA-install-dir\iwc\tomcat\ignite_config\iwc\repo.properties
DPA returns an invalid login error
Verify that the DPA monitoring user exists in the CDB. Common users (prefaced with C##) exist in only one CDB.
DPA does not start
Check the logs for error messages.
  • If the logs do not have error messages, but you can't access DPA from a browser:
    • Make sure you do not have a firewall preventing DPA from listening on the ports that are specified in the following file:
    • Make sure the client machine can ping the DPA server.
  • If errors in the logs indicate that the default ports are in use, change the ports that DPA uses.
SSL
SSL is enabled by default. This includes an SSL connector in DPA-install-dir/iwc/tomcat/conf/server.xml, and a keystore file with a self-signed certificate in DPA-install-dir/iwc/tomcat/conf/.keystore.
On AIX, the following attribute must be added to the SSL connector in DPA-install-dir/iwc/tomcat/conf/server.xml:
algorithm="ibmX509"
For details on setting up SSL, see the knowledge base article Enable SSL for DPA.
Firefox browser
Logging out from a Firefox tab or browser will also log out of sessions you have open in other tabs or browsers. This is because Firefox shares the session cookie between browsers and tabs.
Platform Connect cannot connect to a MySQL server
When DPA attempts to send alert information to SolarWinds Observability (SaaS) using Platform Connect, the following error is returned:
tls: failed to verify certificate: x509: certificate relies on legacy Common Name field, use SANs instead
This occurs when the MySQL server uses SSL and the trustServerCertificate property is set to false, but the certificate uses only the common name (CN) field. To resolve this issue, see Add a subject alternative name to a MySQL server SSL certificate.
Registering a MySQL database fails with the message Public Key Retrieval is not allowed
While you are trying to register a MySQL database as a monitored database instance or as the DPA repository, the registration wizard fails on the final step with the following message:
This occurs because the RSA public key cannot be retrieved on an insecure connection. MySQL 8.0 added the caching_sha2_password authentication plugin and made it the default. This plugin uses RSA public key encryption to protect the user’s password in transit.
To resolve this issue, complete the following steps when you retry the registration:
  1. On the panel of the registration wizard where you enter connection properties, open the Advanced Connection Properties text box.
  2. Enter one of the following properties:
    • useSSL=true
    • sslMode=preferred
