Documentation forDatabase Performance Analyzer
ASMI metrics collected by DPA
The following sections list the metrics that DPA collects for Azure SQL managed instances (ASMIs).
  • Learn how to view these metrics and change the thresholds.
  • For detailed information about resolving issues, click the next to the metric on the Resources tab. The Information link is not available for all metrics.
  • If the database instance runs on a virtual machine (VM), metrics collected for the VM are described in VM metrics collected by DPA
Connections
Metric Description
Connected Devices The number of distinct client machines connected to this instance (even if the connection is idle).
Connected Users The number of distinct users (that is, login names) connected to this instance (even if the connection is idle).
Sessions The number of sessions connected to this instance (even if the connection is idle).
CPU
Metric Description
Core Count The number of cores used by the instance.
CPU Utilization The amount of CPU being used as a percentage of the limit of the service tier.
Signal Waits
The percentage of overall time that sessions are waiting for a CPU to become available. Anything over 20% indicates a possible CPU resource bottleneck.
Examine the overall wait events for the server as a whole. A high signal wait percentage could be due to an increased number of sessions, so examine the overall workload for the server as well. Take steps to either reduce the overall runtime for queries or reduce the total number of sessions.
Disk
Metric Description
Data I/O Utilization The average data I/O usage as a percentage of the service tier limit.
Log Write Utilization The average transaction log writes as percentage of the service tier limit.
O/S Disk Queue Length The number of I/O operations waiting for disk drives to become available for the entire system (includes all instances on this machine). Spikes of high disk queue length may be normal, but if this is high for an extended period, you could have an I/O bottleneck. Drill in to DPA Trends charts to examine queries with I/O wait types during the timeframe.
Page Reads The number of SQL Server physical reads from disk to memory. OLTP workloads are typically about 80-90 per second with higher values (or spikes) being an indication of insufficient storage performance, insufficient indexing, or not enough memory.
Page Writes The number of SQL Server physical writes from memory to disk. OLTP workloads are typically about 80-90 per second. If this is high (or spikes) it needs to be cross checked with lazy-writes/sec and checkpoints in order to determine if the issue might be due to low memory.
SQL Disk Read Latency Disk read latency from dm_io_virtual_file_stats DMO.
SQL Disk Write Latency Disk write latency from dm_io_virtual_file_stats DMO.
Total I/O Wait Time
The sum of all I/O activity for all database files. If this is high:
  1. Examine the current physical structure of databases on the server to see if it is possible to reduce I/O load by redistributing the database files to distinct disks.
  2. Examine queries and database design to determine if they can be tuned to reduce I/O.
Total Read I/O Wait Time The sum of all read I/O activity for all database files.
Total Write I/O Wait Time The sum of all write I/O activity for all database files.
Memory
Metric Description
Buffer Cache Hit Ratio
The rate at which SQL Server finds the data blocks it needs in memory rather than having to read from disk for this instance. By itself, the buffer cache hit ratio is not very meaningful except for servers with undersized memory settings. Tuning queries and performing index optimization is the best way to increase buffer cache hit ratios. To see the current metrics for the buffer cache, run the following query:
select * from master..sysperfinfo where object_name like 'Buffer Manager'
Buffer Cache Size The current size of the SQL Server Buffer Cache.
Log Bytes Flushed The number of bytes of information being flushed per second.
Log Flushes The number of log flushes that occur per second.
O/S Memory Utilization The percentage of memory being used for the entire system (includes all instances on this machine). If this is high and the Memory Paging Rate metric is high, you might need to increase the amount of physical RAM in the server, reduce the load on the server, or change the server memory configuration. Run sp_configure and review settings for "max server memory" and "min server memory" to determine amount of memory allocated to SQL Server.
Page Life Expectancy The number of seconds a page will stay in the buffer pool without references. A lower value (for example, under 300) indicates the buffer pool is under memory pressure and you should add more memory to the system (enable AWE on 32-bit systems) or find the process in Task Manager that is consuming outside of SQL Server.
Plan Cache Size The current size of the SQL Server Plan Cache.
Procedure Cache Hit Ratio
The percentage of time when SQL Server looks for an execution plan in the procedure cache and finds it for this instance. If this is low, try to write more reusable code or consider increasing the size of the procedure cache. To see current metrics for the procedure cache, run the following query:
select * from master..sysperfinfo where object_name like '%Plan Cache%';
SQL Compilations
The number of compilations performed by SQL Server per second. Compilations are a natural part of SQL Server operations but do use CPU and other resources. Compare this to the Batch Requests/sec metric to understand if this metric is too high. Minimizing compilations will help overall performance. For more information, see the following Microsoft Knowledgebase article: http://support.microsoft.com/kb/243588.
SQL Re-Compilations The number of re-compilations performed by SQL Server per second. Re-compilations occur for many reasons but this number should typically be low.
XTP Storage Utilization The percentage of available XTP Storage being used.
Network
Metric Description
Round-trip Time The round-trip time when running "select 1" against this instance (includes network time but not connect time). If this is high, contact your network administrator to understand network latency.
Sessions
Metric Description
Active Sessions The number of sessions in this instance actively performing work or waiting for a resource (excludes idle sessions).
Batch Requests The number of batches being executed by SQL Server every second.
Blocked Sessions The number of sessions that are blocked in this instance because another session is using a needed resource.
Max Session Utilization Maximum concurrent sessions as a percentage of the limit of the database's service tier.
Max Worker Utilization Maximum concurrent workers (requests) as a percentage of the limit of the database's service tier.
Transaction Rate The number of transactions being executed every second in this instance (the Transactions/sec statistic from sysperfinfo for the instance).
TempDB
Space required by the tempDB database fluctuates based on the number of queries running and the nature of those queries. Use tempDB metrics to monitor the amount of space required.
Metric Description
TempDB % Free Space
The percentage of unused space in tempDB.
If tempDB fills up and cannot autogrow, the performance of all queries will be affected as they wait for access to tempDB.
TempDB Size
The amount of space currently allocated for tempDB. Use this value to track the amount of space tempDB typically uses and plan for storage requirements.
Each time SQL Server is restarted, tempDB is recreated using the default size. By default, tempDB grows automatically as needed. However, the files cannot be used during that process, and excessive autogrowth can lead to fragmentation. If tempDB typically needs to grow by a large amount, consider increasing the initial size.
Waits
Metric Description
Total Instance Wait Time The total wait time for the database instance.
